Engine Question
Old Apr 11, 2013 | 7:39 AM
Grunkey's Avatar
Default Engine Question
Hi all. Got a 95 2500 Vandura. 192,000 and change and never left me stranded. Pulling my small popup from the beach back home and started to come into some grades. under load she wanted to flame out, buck a little bit. No power at all. Nice and level no problem, any hills would slow down from 70 to 50 or so. Replaced the plugs wires cap and button 6 months ago. Maybe a fuel filter clog? Or could be a compression seal or vacuum? Just need a starting point.
Old Apr 11, 2013 | 11:28 AM
Does it do it with a full tank of gas? Does it do it only when the tank is very low on fuel?
Old Apr 11, 2013 | 12:01 PM
canucklehead's Avatar
Either its a fuel pump issue, or maybe the egr valve or the o2 sensors......
Whatever the case...sounds like its leaning out....
Old Apr 11, 2013 | 4:40 PM
DougE's Avatar
That's a typical symptom of a clogged fuel filter. You get enough gas to run straight and level but when you try to speed up to pass or maintain speed up a grade you don't get sufficient gas to produce the additional power needed. If you're on the road, sometimes a tank of premium will have the cleaners to dissolve enough of the clog to get you home.
Old Apr 11, 2013 | 6:45 PM
If its the fuel filter you are in luck. Its under the van along the frame....much easier and cheaper than replacing the fuel pump.
Old Apr 12, 2013 | 9:20 AM
Grunkey's Avatar
At that point it was about half a tank. I checked my wires for looseness or cracks, and i'm changing the filter this weekend. I ran my dual exhaust and it ended up right under the filter! Gonna have to get flexible! I'll let you know, thanks.
lph008
Feb 22, 2014 7:13 PM
koolminx
Nova & Chevy II
May 21, 2010 10:17 AM
adamant
Feb 15, 2009 8:49 AM
Helliex
Feb 1, 2009 10:57 PM
nfruge56
Dec 6, 2006 1:31 AM
