Express 2005 oil pressure dropping to 0 psi
Old June 2nd, 2016, 6:19 PM
  #11
REO
REO's Avatar
When I took the pump off I found a lot sludge and sedimentsin the oil pan, plus a lot dry oil stuck all over gears and chain, as well as everywhereinside the engine. I removed the as well the oil pan and the valve covers and Ifound the same, nasty oil sediment very dry and a bunch of sludge. I assumed allof these put a lot of wear in the main bearings, don’t you think?
