Hard to find brake system parts
Old April 4th, 2016, 7:04 PM
Steve Morris's Avatar
Default Hard to find brake system parts
I have a 1992 Chevy G20 conversion van. I have a leak in my brake system and it's the Hydraulic Brake combo/monitoring valve. Discontinued. Hard to find. Anyone know where I should be looking to find one. Need a valid part number too. I have come up with all kinds of part numbers but am not sure which is correct. I have contacted a couple of online parts companies and asked for verification that their part will fit my van but waiting to hear from them. Thanks for the help.
Old April 5th, 2016, 10:19 PM
canucklehead's Avatar
Have you tried a cross index with the same part used on chev gmc pickup trucks?
Its just a valve to reduce pressure to the rears, and delay pressure to the fronts.....
I bet its not that different that the pick up one.
Also it may make it easier to find one at a wrecker.
Old April 5th, 2016, 10:52 PM
Default Thanks for the feedback/suggestions.
I have a lead on the part from a parts place in Indiana. Will followup on that tomorrow. Hopefully that will be productive.
I will try what you suggested about cross reference and I have started looking at junk yards.
Thanks again.
Old May 19th, 2016, 10:21 AM
Stacozo's Avatar
If you haven't already found the correct part at the yards, check on Cheapest GM Parts - Shop the Cheapest OEM GM Parts, they have a ton of stock and are very reasonably priced.
Old May 19th, 2016, 3:25 PM
I ended up getting the part from a junk yard online. Used part. It worked.
