No Spark
Old Jan 21, 2013 | 8:14 AM
Ken Dehart's Avatar
Default No Spark
2001 Savana 4.3 with 223,000 mi. acting up again, has new ICM,coil,cap+rotor,pickup coil under cap,wires+plugs, crank and cam sensors, bat+alt,fuel pump+filter, oxygen sensors ....cranks over wont start. has fuel pressure no spark from coil.... ran fine, all new parts added at different times while I was trying to do a self diagnostic and each time started ran for a few days and would do the same, just shut off and crank but wont start. While trying to start I checked all wires and wiggled to see if it was a connection problem....could it be the computer ???
Old Jan 26, 2013 | 5:26 PM
go-part's Avatar
Former Sponsor
You replaced all those parts, yet you forgot the most common thing to check first... your fuses and relays
Old Jan 26, 2013 | 7:05 PM
kevinkpk's Avatar
More than likley not the computer. Recheck wiring, and with key switch on, do you have voltage to the distributor?
Old Jan 29, 2013 | 8:33 PM
Ken Dehart's Avatar
I did check the fuses and relays I broke down and took it to Darby GMC in Venice and found out the ICM was bad because of a short in the wire leading to it $575 later and it starts and runs fine. I had no way of knowing without a computer diagnostics.... Thanks guys for the replies
mamulan
Aug 20, 2014 8:39 AM
stdhawaii60
Dec 24, 2010 11:14 AM
catill
Aug 30, 2010 11:07 AM
rodentman
Sonic (Aveo)
Jul 5, 2005 11:37 PM
