scanner what brand
Old Jul 29, 2012 | 5:55 PM
jnaas2's Avatar
Default scanner what brand
Cant find the problem with my van without one, anyone have any input on what brand and what the readings should be, 1996 gmc g/3500 5.7 tbi.
Old Jul 29, 2012 | 6:22 PM
I bought a launch c-readerVI. Its $169 in Canada...probably much cheaper in the USA.
Its not a full function scan tool but operates all 10 modes of obdII.
reguardless of what you get; get something with theses functions:
-Displays all generic and manufacturer powertrain codes
-displays live data/datastream
-displays freeze frame failure data
-displays OBDII monitor status
Old Jul 29, 2012 | 7:29 PM
jnaas2's Avatar
Borrowed a actron code reader for obd II, went to see if there were any codes and it wont plug in. The plug on my van is square not angled sides like the obd II scanner. Looked up the vin number and it says that its a 1996, but Im starting to think that its a obd I. Ive never used a scan tool before so not for sure. If this is the case now I know why Im having trouble trying to trouble shoot this engine
Old Jul 29, 2012 | 8:49 PM
MDTAHOE's Avatar
Professional Mechanic
To my knowledge there are no OBDII TBI engines. If you have throttle body injection then most likely you don't have OBDII
Old Jul 29, 2012 | 10:05 PM
Check Ebay, they have OBD2 to OBD1 conversion cables.
Old Jul 29, 2012 | 10:44 PM
should have central port injection unless you have a late production 1995.
the gm schematic for a 1996 g van with a 5.7 shows a 16 pin connector. but you are definitly describing a obdI connector
whats the 10th character of your vin? s is 1995, t is 1996.
Old Jul 29, 2012 | 10:54 PM
jnaas2's Avatar
The 10th character of my vin is a T, According to the vin its a 96 but I am starting to believe its a late 1995 model
Old Jul 30, 2012 | 2:52 PM
jnaas2's Avatar
Does it take a special scanner to read obd I or will a obd II scanner with a different cable read them
Found on this web site how to jump the connector and watch the check engine light for codes. There is nothing that shows it just flashes 12, meaning everything is okay, I know that cant be right because it knocks and has no power, do you think the computer could be bad?????
Old Jul 30, 2012 | 4:36 PM
Nightwish2's Avatar
as far as I know odb1 can bei flashed out with a simple lamp. There are several Manuals on the net..
Old Jul 30, 2012 | 8:12 PM
jnaas2's Avatar
Put a timing light on it and disconnected the brown wire with black stripe which was at the distributor and it dropped from 8 degrees advance to 0 degrees advance, But when you give it gas the engine advances 4-6 degrees. Is this normal or do I have a bad distributor or timing chain
