Weird horn
Old Jun 15, 2012 | 11:10 AM
KHD's Avatar
KHD
Unhappy Weird horn
Need some input on horn problem. 2004 Chev Express 1500 explorer Conversion. Lately my horn doesn't want to work or gives a very faint beep, also does the same when using the keyless fob. It only does it when extremley HOT outside, hi 80s and up. Once you let the vehicle sit till things cool down everything OK. No problems in winter or other times. Could the computer be overheating? relay? bcm? horn itself?? WEIRD, THANKS in advance
Old Jun 15, 2012 | 4:45 PM
Squigie's Avatar
Check the ground and wiring.
Trace it all the way back to the relay, to make sure you don't have a wire short that changes as the insulation relaxes with heat.
maddog5461
Jun 5, 2016 7:41 PM
Zach
Aug 7, 2011 7:29 PM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
richardbentz
Aug 13, 2006 12:39 AM
