2005 Chevy Silverado
Old Jan 28, 2012 | 1:53 PM
fixitman's Avatar
Default Help with 2005 Chevy Silverado Radio
I recently removed my factory installed radio to remove a stuck CD and when reinstalled the radio will not work, no display, wont turn on or off. Anyone have any idea what could be wrong and how to fix it ??
Old Jan 28, 2012 | 5:19 PM
EinST's Avatar
Welcome to the forum. I suppose you didn't disconnect the battery before installing the radio? You may have accidentally blown the Radio fuse in the underhood fuse block.
Old Jan 28, 2012 | 5:48 PM
fixitman's Avatar
Thank You. You are correct. I didn't unhook the battery but I did check the fuse underhood and it was OK. Are there any other inline fuses that could have blown ?? Thanks for your help
Old Jan 28, 2012 | 6:11 PM
EinST's Avatar
No, but verify the fuse has battery voltage. These radios are so integrated into the vehicle electronics that you may need to take it into the service department.
Old Jan 28, 2012 | 6:15 PM
fixitman's Avatar
I will check that. I did notice that the theft lock light is still flashing so it must be getting power just nothing on the display
Old Jan 30, 2012 | 5:14 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> fixitman,
There are two fuses available for the radio, one for the Audio System and another for the Radio Amplifier. You may want to check to make sure they are both in working order.
For your reference, this information is available in the owner's manual on page 5-135, with a diagram available on page 5-132. A digital copy of the manual is available at: http://www.extendedgmwarranty.com/ow...-Silverado.pdf
I hope this information is helpful. If not, you may need to take the vehicle in for an inspection.
If you have additional questions, please feel free to contact me.
Please keep us posted.
Louis
GM Customer Service
tina75
21
Nov 28, 2018 10:30 PM
wmjackson15
Apr 24, 2009 3:03 PM
shadyg07
Feb 27, 2009 7:04 PM
hfb1957
Nov 21, 2008 4:26 PM
sgiles
Aug 2, 2008 9:28 PM
