Notices
94 s10 4x4 4.3 vortec center/drag link
Old October 12th, 2009, 6:55 AM
SPADEFRICKINOLOGY's Avatar
Default 94 s10 4x4 4.3 vortec center/drag link
Hi everyone and thanks in advance for your time here. Recently i purchased a 94 s10 that had alot of play in the steering wheel and also about a month after buying the truck i noticed it had demolished the new tire i put on the front passenger side. So needless to say i started investigating and found that the center/drag link is broken and im trying to find out how to replace it. I ordered the part already from my local advance auto and was amazed it was only $34. Do i need any special tools and do i need to remove anything else to get to the center link.
Old October 12th, 2009, 6:56 AM
Thanks again
Old October 12th, 2009, 5:56 PM
therewolf's Avatar
Hey SPADEFRICKENOLOGY,
Welcome to the Chevy forums.
At this point you'll probably want to invest in a repair manual, they're only 12.$. The drag link may have ruined your tire(s), but it's because it's having a bad effect on your front end alignment.
If you're sure you can handle replacing the drag link, and doing a front end alignment yourself, (it's not impossible) then you're all set.
Otherwise, it might be in your own best interest to get the front end aligned by a shop when you're done installing the drag link.
Danistheman1234
Silverado & Fullsize Pick-ups
May 18th, 2011 10:49 PM
Danistheman1234
May 14th, 2011 8:55 PM
ridnlowsilverado
Nova & Chevy II
February 19th, 2011 8:04 PM
JR2500H.D
18
September 7th, 2009 3:29 PM
fastfirebird
November 10th, 2006 5:20 AM
Quick Reply: 94 s10 4x4 4.3 vortec center/drag link
