dome lights don't work
Are you referring to Pontiactalk.com?
Yes. All the lights on your car are fused. Check the interior fuse panel for DOME.
We generally don't snub questions about other GM products. As long as it has a Chevrolet counterpart. I guess the Beretta would be the Grand Am...
It might also be on a fuse with some other less noticeable circuits, that's not marked.
Also, try a test light at the socket to ground. If it lights up you have power at the socket, but probably a bad ground, which is not uncommon.
Check for a fuse labelled ALARM...should be a 15amp fuse in the instrument panel fuse box
And we'll do our best to help on ALL makes and models...import or domestic
Yeah,
Owner's Manual(if you can get them) @30.00
Hayne's or Chilton's manual(almost always available)@12.00
I know not what others may do, but I'll take the repair manual any day. IMO, there is no better substitute.
LeeA
Silverado & Fullsize Pick-ups
April 13th, 2012 4:28 AM
charlie93chevy
April 21st, 2007 5:52 PM
