Notices
output voltage of a coil
Old January 8th, 2010, 6:21 PM
RayC's Avatar
Default output voltage of a coil
Does anybody know what the output voltage of a stock 60's - 70's chevy coil would be? I'm just trying to help out a friend
Thanks
RayC
Old January 9th, 2010, 11:09 AM
BamBam's Avatar
If memory serves me correct in say 85 they were hovering around 30K so I would imagine a little less.
Old January 9th, 2010, 3:06 PM
RayC's Avatar
Thanks Bam Bam
That's what I was thinking. I have a buddy that's wanting to use one for a powder coating power supply. He's talking about using a 24 volt power supply Thur an rheostat to provide voltage to the coil primary. In turn getting 30,000 to around 50-60,000 volts out of the secondary windings
RayC
Old January 10th, 2010, 6:15 PM
BamBam's Avatar
well you can use a newer coil and get pretty close to that with 12V...
something else that may work is a neon sign transformer they put out those kind of voltages
Old January 10th, 2010, 6:16 PM
BamBam's Avatar
wait a minute...
you need DC the neon sign transformer will be AC i guess you are better off going with the coil.
Old January 11th, 2010, 4:10 AM
RayC's Avatar
Originally Posted by BamBam
wait a minute...
I think the neon sign transformer does put out DC (not sure) but it's only 6000 volts. My buddy was needing around 25,000 to 50,000. I was thinking. Rheostat and a 24 volt powder supply would do what he wants.
Thanks
RayC
Old January 12th, 2010, 8:45 AM
a. palmer jr.'s Avatar
It would have to have AC connected to the coil (transformer). A car uses points or electronic circuits to accomplish this. Straight 12v dc hooked to the primary side of a coil accomplishes nothing but produces heat such as burning the coil up.
mhp8982
February 16th, 2011 9:13 PM
mryamaha
Equinox
January 15th, 2011 9:04 PM
freddyp
November 18th, 2008 11:16 AM
2007SUBURBAN
December 28th, 2007 9:13 AM
haidangwa
January 17th, 2007 9:16 PM
Quick Reply: output voltage of a coil
