2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Location of Blend Door Motor on a 2004 Impala?
Old August 30th, 2009, 11:12 PM
woodalee's Avatar
Default Location of Blend Door Motor on a 2004 Impala?
Can anyone tell me how to locate the passenger side blend door motor on a 2004 Impala? Heat and defrost is not working on any setting on passenger side. Does work on driver side. Took it to the dealer and they said it would be $600 plus to replace blend door. Thanks in advance for the help.
Old August 31st, 2009, 3:23 PM
Banned
shawnvw's Avatar
Mode Valve Actuator Replacement
Removal Procedure
  1. Remove the right instrument panel (I/P) insulator.
  2. Remove the I/P compartment.
  3. Disconnect the electrical connector from the mode actuator.
  4. Remove the screws that secure the mode actuator (1) to the HVAC module assembly.
  5. Remove the mode actuator from the HVAC module assembly.
Installation Procedure
  1. Position the mode actuator, aligning the slots in the electric actuator drive to the flats on the shaft.
  2. Align the locating hole to the alignment pin on the HVAC module assembly.
  3. Slide the actuator drive completely onto the shaft, with the mounting holes flush with the mounting screw holes on the HVAC module assembly.
    Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Install the screws to the mode actuator (1).Tighten
    Tighten the screws to 1.5 N·m (13 lb in).
  5. Connect the electrical connector to the mode actuator.
  6. Install the I/P compartment.
  7. Install the right I/P insulator.
  8. Calibrate the actuator.
  1. Calibration Procedure
Use the following steps to perform the calibration update:
  1. Turn OFF the ignition.
  2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
Important: The module memory will not clear if the battery positive voltage
circuit fuse is installed in less than 60 seconds.
  1. Wait 60 seconds.
  2. Install the fuse.
  3. Wait 60 seconds before moving the HVAC controls.
Old November 21st, 2009, 12:14 AM
titanss's Avatar
Is this the part i need? 2001 Impala with single zone HVAC.
Attached Thumbnails Location of Blend Door Motor on a 2004 Impala?-impala.jpg
papaseven
Silverado & Fullsize Pick-ups
April 15th, 2015 7:54 PM
los7883
April 12th, 2010 9:36 AM
TNVOLFAN
March 18th, 2010 7:36 PM
GBS
October 2nd, 2009 4:17 PM
RayenTiger
January 17th, 2009 11:50 AM
Quick Reply: Location of Blend Door Motor on a 2004 Impala?
