Wire chart impala 2000
Hi there.
Today i got in the mail my remote control central door lock.
It said i can hook up my power window to this remote.
Does any body can help me with the wire chart for Impala 2000?
Thanks in advance Quint
Hi Quint, since this sounds like an aftermarket remote starter, you will probably need to be tapping into the existing wiring systems on the Impala, correct? I don't know of a master wiring chart for the Impala, but they do list the wiring colors on the connectors for each of the sub-systems in the car such as the steering column or ignition lock, where you will have to work some magic with the PassLock Theft Deterrent system. Biggest thing is to read the install instructions and make a list of what this system needs to connect to, make a chart, then fill in the colors required for each signal line.
barnesam
December 31st, 2022 2:34 PM
legolas894
February 18th, 2011 12:37 PM
