Rear 6X9 speakers
Rear 6X9 speakers
Hello all, I was wanting to replace the factory 6x9's with a pair on Infinity's I have laying around, they are not removeable from the trunk, does anyone know how to get them out??. Thanks in advance for any help..
RE: Rear 6X9 speakers
You have to pull the rear seat(bottom & back) to get at them. Pull the seat out, take off both C pillar covers, remove the rear parcel shelf and the speakers are right there. Just undo the clip and they're out
Remove the rear speaker by depressing the tab and lifting the speaker straight out.
Hey thanks a bunch!, are there any bolts to remove to get the seat out?, the C-pillar, that's the plastic cover next to the window, right? any bolts to remove to get those out too??
Youare right, the c pillar covers are the plastic pieces at the rear window. There is a small access tab you remove with a small screwdriver to get at the bolt holding them on. See the pic
If you want to try to do the job without removing the seats, its up to you...I have done it before. Its really tight but do-able.
Fold down the seat back and remove the 2 10mm bolts near the seat latches and pull the seat back as far as you can....using a pry tool, pull out the push pins holding the rear parcel shelf cover to the body. lift the cover up and pull it out and you can access the speakers.
Thanks again, I've kept this car in mint condition and didn't want to damage it installing the speakers. The fact. 6x9's don't have any tweeters at all so the Infinity's should be a good upgrade. Now to find a hole in the firewall so I can hook up an amp..
bmac
November 12th, 2006 12:13 AM
