Help with engine code PO449
I need some help with engine code PO449. I replaced the Canister located underneath near the fuel filler neck and also replaced the solenoid under the hood. After unhooking the battery cables and reattaching them to see if the computer would reset my engine light is still on. Even went so far as to check the fuses and replace the gas cap.HELP
