4.3 problem
New User
Awaiting E-mail Confirmation
4.3 problem
1990 4.3 Idles fine. Rev up fine, but will fall on it's face when you you put it under a load. ( drive ). Has new fuel pump. TBI kit. Cleaned injectors. Clean egr. Spark plugs. Cap rotor. Map good. New tps sensor. Timings right. Chased timing wire back to ecm it's OK. Put a can of sea foam in a 1/4 tank of gas ( truck had sat for a while ). Ignition switch? Only place I Can think of that pull the selector would ground out the ignition. Engine light is not on. Has no codes.
Rosariods
July 21st, 2011 8:13 PM
BayAreaChevyGuy
Silverado & Fullsize Pick-ups
January 6th, 2011 2:27 AM
chenzo
March 21st, 2010 5:35 PM
99silver
February 2nd, 2008 4:14 PM
