S-10 & Blazer 1982-2005
backfire when i rev it?
Old July 18th, 2011, 1:22 PM
rhaser's Avatar
Default backfire when i rev it?
01 blazer. Started running bad. ive replaced the fuel pump wires cap plugs and the o2 sencor. From suggestions?? The truck runs fine for the first 2 or so mins. then just starts dumping fuel? Or is the ignition breaking down and not burning it? i didn't use ac delco parts. i read i should have!! The first time i had the codes read it was pretty much every sensor. i took off the batt terminal and reset the ecm. Now the only code is bad injector #6??? I'm lost and broke. any help would be great!!!
Old July 18th, 2011, 2:27 PM
rhaser's Avatar
Could this a crank shaft sesnor prob?
Old July 20th, 2011, 11:55 PM
cdf912's Avatar
If the code says it the fuel injector #6, why would you think its not that? Perhaps the injector needs to be replaced?
shopkeeper
November 19th, 2008 7:46 PM
russ27444
Silverado & Fullsize Pick-ups
March 16th, 2008 3:00 PM
TexPhoneGuy
April 17th, 2007 1:00 AM
LuangTom
August 1st, 2006 3:53 AM
Quick Reply: backfire when i rev it?
