S-10 & Blazer 1982-2005
98 s-10 blazer a/c problem
Old June 21st, 2011, 1:28 PM
jhtitan's Avatar
Default 98 s-10 blazer a/c problem
I have a 98 s-10 blazer. the AC was empty (it had been sitting for over 2 years when I got it) Truck runs great but I am trying to get the AC working and am not sure where to start. I have charged the system, but the clutch is not engaging. Per a local suggestion I tried putting 12V to the coil (there was no voltage at the coil? connection) this engaged the compressor and I added some more coolant. which overcharged the system. when it was over charged the compressor would cycle off and on on its own, but once I got the pressure back into a safe zone it stopped and wont come on by itself.
where should I look next? is the compressor bad, or is there a sensor I need to check/swap?
any help would be great, Thanks in advance!
Jon
Old June 24th, 2011, 10:29 AM
uneasy_rider's Avatar
You have high pressure and a low pressure cut out switches you can check, compressor control relay, can be somewhat tricky to diagnose. Did you have a vacuum pulled on the system prior to charging? Could be moisture or contaminants in the system.
Old July 17th, 2011, 6:07 PM
mavmannate's Avatar
Everytime ive charged a system, I put a small vacuum on it so that it takes easier. you can also gauge the amount already inside too.
If you didnt do that, it may need to be drained....
Eddie02780
May 11th, 2015 5:19 PM
stshadow
April 22nd, 2011 9:48 PM
phmiller
April 27th, 2010 7:08 AM
phmiller
September 19th, 2006 6:02 PM
shawnCRX
June 15th, 2005 1:05 AM
Quick Reply: 98 s-10 blazer a/c problem
