Crank but wont start need help
Okay so i have a 1996 s10 manual 4.3vortech and it was running fine i was pulling 2 tdc codes wich where mass air flow sensore and a cam shaft positioning sensore i replaced them as well as cap and rotor. Spark plugs and cables i went to go start after everything was back together and thats when every thing started with the will crank but wont start. I have fuel presser,spark, compression, timing the main things you need but still nothing.. i have all ready put new fuel pump. Msd coil over.alternater. ecm. Egnition switch. Pluse the cap and rotor.distribuator spark plugs and cables and maf but still wont start any suggestions or advice before i send it in to a shop and fork more money over
