S10 & Blazer DIY and Useful Threads This section is strictly for frequently asked questions pertaining to S10s and Blazers.
BOLT PATTERN & RIM DIMENSIONS---S10/Blazer
Old January 23rd, 2009, 11:48 PM
EvansBlue's Avatar
Default BOLT PATTERN & RIM DIMENSIONS---S10/Blazer
Rim- dia.15 x wid.7
Bolt Patt.- 5 lug x 4.75"
Back Spacing- 4wd: 6" 2wd: 5.5"
Old August 23rd, 2009, 11:02 PM
dthompson2121's Avatar
Smile
I own a 1999 s-10 blazer and have been searching around for some new wheels & tires but want to make sure that i have the right bolt pattern. im looking to eventually lift my s10 and get a bigger/wider wheel and tire and kinda wondering what size rims/tires i should get as well...
different forums say alot of different things that the right pattern is 5x4.75". so far this is what ive gone with until i found 5x(120.65mm) and not sure if thats the same thing as 4.75".
thank you anyone who can help
Old November 3rd, 2009, 8:29 PM
ridebmx563's Avatar
Will these wheels work with my 1994 s10 blazer 4wd, even though the backspacing isn't the same.
http://www.bassettwheel.com/dot.html
Old January 22nd, 2010, 9:43 PM
jklm545's Avatar
Unhappy Cold weather,poll mood!
The bad weather, the cold, the white.Today's weather is becoming worse and worse.People really begin digging in. Just hope the future will be better,Really worried about our kids!
Old March 4th, 2010, 8:35 PM
mikeross's Avatar
I've got a '99 blazer too and so far the parts that I have installed were the 5x4.75" cuz it's really the right pattern and some nerf bars. I just don't know if the other sizes would be compatible enough.
Old June 15th, 2010, 8:53 PM
KRD
KRD's Avatar
Red face bolt pattern
take 120.65 and divide by 25.4 to convert to inches. and to save you the trouble the answer is 4.75
Old September 16th, 2012, 7:21 PM
gabesblazer99's Avatar
I agreed, and if you want to know the tire's sidewall height (from rim to tread) simply do this formula...
225/50/R16 50 indicates the sidewall height.
225/24.5=8.86" (wide of the tire) now multiply it by 50%. (.50) = 4.43" from rim to tread.
if the tires was 225/70/r16 225/24.5=8.86 x .70 = 6.20"
why 24.5 ? cuz is the number of milimeters per inch.
Old April 15th, 2013, 12:02 PM
Bullgod's Avatar
Bolt pattern on my 98 4x4 Blazer is 4.5
Old April 24th, 2015, 7:55 PM
mrcor's Avatar
what is the bolt pattern for the rim a 2002 Chevy Blazer 4 by 4
Old August 22nd, 2015, 9:37 PM
B.A. Shadetree Mechanic's Avatar
Default Bolt pattern
120.65 mm divided by 25.4 = 4.75" . So yes this is the same bolt circle, however the offset may be different .
Quick Reply: BOLT PATTERN & RIM DIMENSIONS---S10/Blazer
