S-10 & Blazer 1982-2005
Stutter under power
Old May 30, 2014 | 8:45 AM
  #11
roberthancock's Avatar
Default stutter under accelerated.
Originally Posted by drperry
The pressure seems go
od...
But it should definitely hold the pressure for longer than 2 seconds after the engine is shut off...
It could be the pump is slowly on its way out, as well... Especially if it's never been done.
I have a starter in my 2000 true Chevy Silverado
But definitely something wrong in the fuel system...
Hopefully someone with a more specific idea chimes in soon!
I have to track down random hesitation in mine... Which can apparently be a bad distributor drive gear! lol
I have a stutter on my 2002 chevy 4.3
Cut small plate out of coke can placed it under egr valve to cap it off and engine runs fine put new valve on still have issue reinstalled plate as patch will check wires next almost changed cats thinking they were bad
Changed cap rotor wires map sensor air filter cleaned maf sensor nothing helped till I blocked valve thought it was fuel problem too at first but have new fuel pump already YouTube have great trouble shooting vids too.
Old Jun 24, 2014 | 7:52 PM
  #12
skruzich's Avatar
before i spent any money on parts, i would put a can of seafoam in the tank and run that tank of gas out. That will clean up the fuel system for starters. Might fix the problem.
Old May 12, 2015 | 7:53 PM
  #13
stewieL's Avatar
Default Didn't work
Originally Posted by Turn this car around
Have you tried any mechanic in the can solutions.I would use some 44K or some sea foam to see if this helps you first.As a one time check you don't want to run it all the time.
I tried Sea Form right off the bat when this happened to mine. I got NO massive smoke blast which was concerning since it may mean something worse like the whole CMPI is shot, but it's weird, the car runs fine at speed, as everyone else said. I will try the poppet valve procedure (if it's different than Sea Form). When I had this before, the dealer convinced me to replace the CMPI versus cleaning. Not cheap.
Old Sep 12, 2018 | 12:26 PM
  #14
kim_c85's Avatar
I have the same exact issue with my 2000 Bravada as York describes. I would really like to know what the outcome was.
InMy83Chevy
Sep 23, 2013 6:42 PM
olguy
Jul 26, 2013 1:14 PM
appomattox
Sep 30, 2011 4:38 PM
billwill
Apr 5, 2011 10:08 PM
wn7186
Dec 20, 2010 10:54 AM
