95 z71 rough driving
Old Jul 22, 2009 | 5:24 PM
  #11
suzuki-guy's Avatar
My truck seems to hesitate a lot more when it's hot out to. I wonder why? If it is because the fuel atomizes different or what?
Old Jul 22, 2009 | 5:42 PM
  #12
silverado_svc_body's Avatar
it could be a slight vapor lock though I wouldn't think it would happen on a tbi system.
Old Jul 27, 2009 | 12:47 PM
  #13
FishBrain's Avatar
Well I think it now comes down to the fuel pump. but does a fuel pump slowly go like this? My experience with the pump is that they just die, outright. can they go slowly?
Old Jul 28, 2009 | 11:55 PM
  #14
seanmiller2002's Avatar
I've never heard of that, not to say that it cant happen of course. But i"ll give you the same suggestion that was given me (that i havent had time or money to check yet). It sounds like it could be the pressure regulator diaphragm in the tbi unit. My guess would be that it isnt holding the pressure high enough when you are at wider throttle settings. Although, that could also mean the pump isn't providing the proper fuel volume.....
Old Jul 29, 2009 | 12:02 AM
  #15
Oh yeah, and i was told that vapor lock is impossible on fuel injected vehicles. And then i was stuck in traffic on an uphill grade in hot weather. The truck start missing sporadically, sputtering, got worse and more frequent till it died and wouldnt restart. At least not till i popped open the hood, and waited ten minutes. Started right up, and drove fine.
Old Jul 29, 2009 | 2:33 PM
  #16
FishBrain's Avatar
I have put a bit of money into it and now at this point I need to get a decent diagnosis before I spend myself blind on parts. I have the pump and new screen and as soon as I get through this tank of gas I am doing the work. Will let you know how it plays out.
Old Jul 30, 2009 | 11:21 AM
  #17
FishBrain's Avatar
FOund out last night that the distributor is loose (dummy me grabbed it and it turned real easily) got a timing light on it and have set and tightened it.
Question, would a loose distributor cause my issue?
Old Jul 30, 2009 | 11:28 AM
  #18
therewolf's Avatar
Well, test drive it for a couple weeks. Yeah, if a distributor is left to adjust it's own timing as it pleases, you may be in for a rough ride.
Old Jul 30, 2009 | 4:02 PM
  #19
mygreenihc's Avatar
Fishbrain,
Check your fuel pressure at the fuel rail. There is a nipple on the fuel rail made for this. I don't know what the specs are for that model truck, but it sounds like low pressure to me. It takes less pressure at idle than it does at higher rpm's. It sounds to me like the pressure is very close to its lower threshold and when your pump stumbles, it drops below the threshold.
Pumps do not usually go out all at once. Except in cases of mechanical or electrical failure, they slowly lose presure until they fall below the adequate threshold, you just do not know there is a problem until all at once. I had an F150 once with dual tanks and it would do exactly what you are describing, then it might clear up for a little while, then it would be back. If I swapped to the other tank, it ran fine.
Old Jul 30, 2009 | 8:35 PM
  #20
Speedy650's Avatar
yes, it could be because your distr./timing. when i had me heads cleaned and surfaced and reset the timing, i unpluged the wrong wire needed to set the timing correctly so whenever i would put my foot in it just a little, the Throttle body would spit fuel up and about die. when i set the timing correctly, it was fine.
