07 Tahoe Foglights
Old Jun 24, 2007 | 6:00 PM
  #11
SENECA's Avatar
Default RE: 07 Tahoe Foglights
Where do the two extensions from the foglights plug in?
Old Jul 13, 2007 | 8:03 PM
  #12
SENECA's Avatar
Hello,still cant find where the extensions plug in on my LS. []
Old Aug 4, 2007 | 2:01 PM
  #13
MUTTY's Avatar
HI, MUTTY HERE. I'M ALSO INSTALLING FOG LAMPS ON MY 2007 TAHOE LS, GM PARTS MANAGER SOLD ME TWO 15839896 LAMPS, 10359413 SWITCH, AND TWO 15789984 HARNESS PIG TAILS, SAID THE PIG TAILS PLUG TO THE BACK OF THE EXTRA ACCESSORY LAMP (CLEAR BULB) TOWARDS THE BOTTOM OF THE HEADLAMP ASSEMBLY?? INSTALLED THE SWITCH AND ALL IT DOES IS TURN ON MY PARKING LIGHTS ON??
THAT ACCESSORY CLEAR BULB'S SOCKET IS FILLED WITH URETHANE ON THE BACK SIDE (CAN'T PLUG INTO IT OR REMOVE THE URETHANE), BUT THE PARTS MANAGER SAID THE HEADLIGHT HARNESS IS THE SAME PART NUMBER FOR LS AS FOR LT/LTZ?? I'M THINKING MAYBE THE REPLACEMENT HEADLIGHT HARNESS IS THE SAME FOR LS AS IT IS FOR LT/LTZ, BUT I THINK THE PRODUCTION HEADLIGHT HARNESS MUST BE DIFFERENT! IT AT LEAST NEEDS A DIFFERENT SOCKET FOR THAT CLEAR BULB? I CAN'T EVEN FIGURE OUT HOW TO MAKE THE LS's CLEAR BULB
ILLUMINATE!
HAS ANYONE SUCCESSFULLY FUNCTIONALLY INSTALLED THE OEM FOG LAMPS IN A 2007 TAHOE LS?? HELP!
Old Sep 12, 2007 | 10:46 AM
  #14
SENECA's Avatar
Someone that has oem foglights should go out and look where they plug into.
Old Jan 21, 2008 | 8:48 PM
  #15
planar52's Avatar
I have a 2008 Silverado and i think i have the same problem as the Tahoe owners. Fog lights have a strange bulb, i was wanting to replace them with xenon bulbs . ANd one more thing, how in the world do you get them out of the holder? Do they turn or pull or what? GM must have had a bad day on this one.
planar52
Old Jan 22, 2008 | 8:38 AM
  #16
snomon's Avatar
Putco is coming out with specific GM fog bulbs in four colors!
http://www.putco.com/product/Fog_Lig...e/part/23001SW
Old Jan 22, 2008 | 8:00 PM
  #17
laredotexas's Avatar
Those look like a fotochop bulb that will melt the housing.. I would like to seesome LED bulbs thatfit to the factory plug.. or even better an HID kit that would fit with no mods...
Old Jan 22, 2008 | 8:25 PM
  #18
sharpetx's Avatar
On the Tahoe, the bulb has two "squeeze" clips, one per side , that you pinch in and pull back on the bulb to remove. I found it easier to take the whole light assembly out through the front of the bumper, then remove the bulb while out? The light assy. comes out by (again) squeezing the tabs on each of the three pins on the backside of the housing, and gently pushing forward towards the front of the vehicle. Careful as the light housing will come clear out, so be ready to "catch it". [8D]
Old Jan 23, 2008 | 12:56 PM
  #19
tbrend's Avatar
ORIGINAL: gcmartin
I just wanted to let you know that the foglights are not 880. I wanted to match them to my 6000K HID's and bought some 880 bulbs in 6000K. They don't fit! GM is using some sort of propietary bulb that no one carries yet.
Take a look at this:
https://chevroletforum.com/m_39999/tm.htm
Old Jan 23, 2008 | 3:49 PM
  #20
negra07's Avatar
laredotexas? do you live there? i live in laredo
