2007 Escalade to 2007 Tahoe Taillight conversion instructions
Old May 10, 2008 | 9:22 AM
  #71
Tahoe MFR's Avatar
Default RE: 2007 Escalade to 2007 Tahoe Taillight conversion instructions
thanks konasmrzfor the amazing topic
i would like to know if u or any other guys faced problems after changing to Esky taillight>> any problem of any kind
i would like to install the amazing light on Tahoe 08
thanks guys
Old May 10, 2008 | 11:37 AM
  #72
tahoe07's Avatar
Glad I could help!
BTW... the harness helps the stop and turn work where it was designed to be two lights and now one light (set of LEDS) does both jobs. If you bypass and only hit brakes it should work. That would have told you it was harness. Brakes and turns won't work with bypass but it was only to test.
Old May 10, 2008 | 1:07 PM
  #73
Welcome to the Tahoe forum. If you want a truly hassle-free plug & play set of LED tails, then I'd recommend the ones that jazejeff sells which IMO look better than the Eskys because they have three rows of LEDs plus one on the side.
Old May 11, 2008 | 11:13 AM
  #74
Tahoe MFR's Avatar
thanks man, i will search for jazejeffpost
Old May 11, 2008 | 4:51 PM
  #75
BMoTahoe's Avatar
I'm a man who appreciates simplicity. I read most of the posts on this topic and I'm glad I came in after the fact. TahoeMFR, listen to 73shark, he knows what he's talking about. I bought a set of the Eagle Eyes LED lights from Jazejef, and trust me, you can install them yourself in less than ten minutes flat with NO, I repeat, NO alterations/modifications. They are direct plug-n-play. They come resistor equipped, and pre-wired. All you have to do is remove & unplug your factory tails, plug in and install the LEDS and enjoy life. The wire harnesses for both sides sit right below the body under the lights.
Old May 11, 2008 | 10:13 PM
  #76
Thanks. Don't forget to slip a towel under your tail lite before you pull it out to prevent scratching your bumper.
Old May 12, 2008 | 9:40 AM
  #77
Tahoe MFR's Avatar
thanks BMoTahoeand 73shark
jazejeff oneslooks great.. but what i like about Esky light that, only 1 row of LED is on.. when u break or turn then all rows of LED turns on,, i am woundring if we can do this with Eagle Eyes LED lights from Jazejef.. also does Esky center break light fitss on Tahoe, its longer and much nicer..
Old Sep 29, 2009 | 9:54 PM
  #78
03chevy's Avatar
Default bodywork
will there be any body work done for this process or do the escalade tail lights fit right in? also, is there any video on the actual conversion?
konasmrz
Dec 9, 2012 1:17 PM
ubtow
Mar 18, 2009 10:32 PM
Rich2007Z71
May 16, 2008 10:51 AM
dsacco
Mar 28, 2007 1:11 AM
