Chevrolet Equinox
Platform: Theta
No heat 06 equinox
Old Oct 29, 2007 | 5:02 PM
wantaC3's Avatar
Default No heat 06 equinox
My 07 Equinox has no heat. Dealer has had the vehicle for 2 days and says he doesn't know what the problem is. His original diagnosis was faulty vent motor. Not the case. The car temps up so its not an engine issue or thermostat issue. We just can't get warm air into the cabin. Has anyone heard of this before? This vehicle also had a defective turn signal. Talk about problems with foundational items which shouldn't break... turn signal and heat!! Dealer is contacting Chevy technical assistance. Any ideas? Thanks.
Old Oct 29, 2007 | 5:06 PM
wantaC3's Avatar
Default RE: No heat 06 equinox
Sorry team. Typo. It is an 06.
Old Jan 24, 2008 | 11:18 AM
jaykoshal's Avatar
I have the same problem with my 05.
So, what happened next?
Old Mar 4, 2008 | 8:12 PM
Ducroix's Avatar
Hey, I had the same problem in my 05. It is the heater core that failed I have talked to others who had the same problem and it was the heater core as well in there cases. I work at a Pontiac Buick GMC dealership and even with my discount its 1300 dollars to replace it and you have to take apart the entire dash to replace it yourself. Hope this helps.
Old Mar 4, 2008 | 8:48 PM
ktm521's Avatar
Before you take the dash apart pull the heater hoses off the heater core and back flush the system and see if that helps
Old Mar 26, 2015 | 3:16 PM
cudaman56586's Avatar
Default no heat on 06 equinox
First pull actuator off on right side of heater box, by blower motor and look for cracked blend door shaft. a lot of problems with them and no recall yet
Old Mar 26, 2015 | 6:42 PM
bearbait's Avatar
Default heater core
Get engine temp. up to normal. Turn heater on. Feel both hoses going to heater core in engine compartment.Both should be warm or hot. If only 1 is, heater core is blocked. Let cool,disconnect hoses(careful because some cores are plastic). Connect garden hose to either side(make up adaptor with hose and clamps) and slowly turn on water. I had same problem and you wouldn't believe the crap that was flushed out!Switch hose to other side and flush again. Put back together.top off radiator and enjoy the heat. Good luck.
Old Mar 26, 2015 | 8:36 PM
This!!
there is a recall for 2006 models.
Gm has issued a special tool for this repair. It will install a sleeve over the broken blend door in vehicle. If all goes well, its a 1 hour fix instead of 6.5 hours to remove and replace the blend door...with the same part that will break in another 6 years. The sleeve repair will not break.
Old Feb 26, 2020 | 7:30 PM
schaut's Avatar
New User
Awaiting E-mail Confirmation
Default schaut
We have a equinox 05 we only get heat if we bleed a fitting to the radiator. Someone said we could have a cracked block air is leaking back into hose so we don't get heat until we bleed it. Any ideas??
Old Feb 26, 2020 | 10:30 PM
if you have air in the cooling system (and its not from incorrect filling after service) the system must be leaking. have the cooling system pressure tested and inspected for leaks.
