Platform: Delta
Also Check out ChevyHHR.net
Key Fob
Old Apr 9, 2008 | 10:27 AM
societydweller's Avatar
Default Key Fob
I have a 2008 HHR with less than 6K miles and the battery on one of the key fobs is low. This apparently causes the alarm to sound at 3A.M. Can anyone tell me how to replace the battery in the fob? Or do I have to take it to the dealership?
Old Apr 26, 2008 | 5:55 AM
ChasHHR's Avatar
Default RE: Key Fob
It's quite easy to change a battery, butYou may have to get it re-programmed.An '08 should certainly still be under warranty - can't imagine a Dealership that would notreplace it( Free )for You !
Old Apr 26, 2008 | 8:29 AM
Default RE: Key Fob
The programming shouldn't be thrown off.
There may be two little screws on the fob, if not, you can just snap it apart with a small screwdriver. There will be a miniscule battery in there. It may be hard to find, but I am fairly certain you can buy them at a walmart or walgreens..
Old Feb 16, 2009 | 3:21 PM
skywrt5's Avatar
Default key fob
I just take mine into pep boys and they replace battery for me; cost of battery is under $5.
Old Feb 16, 2009 | 3:23 PM
skywrt5's Avatar
as far as the HHR key fob reset; you have to take into dealer or locksmith that can reset it because it's newer vehicle. The older vehicle key fobs you can set yourself.
I did find someone to do it for $20 versus $30+ at dealership. thanx anyway for help.
barecub
Nov 13, 2018 6:13 PM
kcarberry
Jan 24, 2014 5:37 PM
ZiL
Uplander
Feb 15, 2011 8:45 PM
chevykicksbut
Oct 23, 2010 12:32 AM
r32rtb
Jun 29, 2006 1:04 AM
