back up lights
Old Apr 10, 2009 | 4:58 PM
suzuki-guy's Avatar
Default back up lights
my backup lights dont work my bulbs are new fuses are good what else could this be?
Old Apr 10, 2009 | 6:50 PM
92chevysilvy's Avatar
Classifieds Moderator
TruckForums Liaison
A peice of asphalt from a recently ran over pothole knocked out your wiring
Old Apr 10, 2009 | 8:00 PM
donjuandejohnson's Avatar
the switch that goes into ur transmission. mine do that too and ive got the switch just havent gotten around to changin it out
Old Apr 11, 2009 | 12:06 AM
I recommend changing the reverse indicator switch on the trans and also the circuit boards that the bulbs plug into (they are cheap).
Old Apr 11, 2009 | 2:25 AM
suzuki-guy's Avatar
is the revers indicator easy to replace?
Old Apr 12, 2009 | 3:21 PM
if were talkin about the same thing all u need is a ratchet and like a 1 inch socket i think. it should be on the drivers side of the trans with a plug comin out of it
Old Apr 12, 2009 | 3:26 PM
therewolf's Avatar
Check your ground wire back there, but more than likely, none of your rear lites would work if it was loose. If it's a separate ground, or it's connected to trailer lites it could be bad.
Old Apr 12, 2009 | 10:22 PM
yeah if someone didnt know what they were doin when they wired a trailer harness that could be it. i got pulled over in my 89 for NO tailights at all...someone muffed that thing up hxc
Old May 19, 2009 | 11:12 PM
suzuki-guy's Avatar
I fixed it!! It was the backup switch on the drivers side of the transmission!
TRUCKDIVA
Jul 22, 2013 6:48 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
georgep14
Sep 17, 2007 8:16 PM
reynaldor@spectralby
Sep 7, 2007 12:03 AM
