K5 Blazer 1969-1994
Platform: Truck, GMT 400
K5 Rear Window
Old May 16, 2009 | 10:57 PM
pcharles's Avatar
Default K5 Rear Window
Hello I just bought a 85 K5 Blazer. The back window would not go down. When you hit the power window switch you could hear the motor but still nothing. Found out the window regulator cable was discounicted. So I conected it and it went down, but it will not go up. If I hit the switch for the window to go up nothing. Please help.
Old May 17, 2009 | 12:16 AM
suzuki-guy's Avatar
Sounds like you got some broken window linkage! I would tear apart and take a look!
Old May 18, 2009 | 6:52 PM
pcharles's Avatar
Is there a manual way to get my back window back up? Motor works going down but hit the switch for it to go back up and nothing. Do you think it could be the power switch? Please help.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old May 18, 2009 | 8:54 PM
suzuki-guy's Avatar
Try having somone push the up button while you pull up on the window! It works sometimes!
Old May 18, 2009 | 10:02 PM
pcharles's Avatar
I tried that and it did not work. So I thought it needed to go all the way down for it to go back up. Is there a release button or switch to unlock the window or even a way to crank it up?
Old Jun 10, 2009 | 10:21 PM
mike79K5's Avatar
Ride of the Month
September 2009
i had that problem on mine. try checking the ground. mine was grounded to go down. but when i went to raise it up nothing. checked the ground and it was it.
Old Jul 9, 2009 | 1:35 PM
Originally Posted by pcharles
Is there a manual way to get my back window back up? Motor works going down but hit the switch for it to go back up and nothing. Do you think it could be the power switch? Please help.fficeffice" /><O></O>
<O></O>
take the inspection cover off and unscrew the cable from the rear window motor,once the cable is loose take some visegrips and grab the cable end and turn ...the window will open or close depending on direction turned...yea might just be in the switch...but this will work till you figure ot out!...........ive had this happen(fun fun )
Old Oct 16, 2009 | 8:59 PM
mikeross's Avatar
Had that problem before.. window regulator cable disconnected so I had to check the wires and all that.. But it's not fixed yet so I push up the window while someone is pressing the button.
Old Oct 18, 2009 | 9:03 PM
frickenbored's Avatar
I drilled a hole in my inspection and stuck the end of the cable thru, I just use a drill to open and close it. I had a working motor in it but my switch was no good, it was always in the up position and eventually it burnt my $55 motor out.
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
jayno20
Sep 11, 2006 10:50 PM
gmares
Feb 4, 2006 5:39 PM
jimbo310
Jun 10, 2005 12:13 AM
