Platform: J-body
00 cavalier buck's & hesitates...
Old Jun 17, 2009 | 9:41 AM
rgrau0311's Avatar
Post 00 cavalier buck's & hesitates...
My 00 cav. will hesitate after I shift into another gear, but only if I throttle heavy. If I shift, then feather the gas pedal there is no bucking. I think its an emmision system problem, any ideas?
Old Jun 17, 2009 | 4:45 PM
Deteoni's Avatar
This is tough without seeing it. If we first weed out that you're not as bad as I am with a clutch! there's no code set and you've stayed on top of the usual routine maintenance stuff. then it could just be some dirt/gum build-up somewhere..i.e. air filter, fuel filter, throttle body, plugs, vacuum leak, etc. start with the cheapest and easiest to check first.
What in the emmision system are you thinking it could be?
Old Jun 19, 2009 | 12:56 PM
rgrau0311's Avatar
Its not the clutch. I replaced the plugs, wires, air cleaner, & fuel filter 2 years ago, so they are pretty new! I was thinking it could be a pvc valve prob. but i dont think my 00 has one. Then i thought it could be a vaccuum leak, but just not sure. No check engine light either!
dab7547
Oct 27, 2012 12:34 PM
pos95suburban
Dec 26, 2011 9:28 PM
Zalu
Nova & Chevy II
Oct 8, 2010 6:38 PM
02cavagrn
Mar 11, 2008 3:28 PM
