Nothing fixes this squeak
Old Jul 3, 2009 | 11:03 PM
kurtchevy's Avatar
Default Nothing fixes this squeak
Okay, I have a really annoying squeak from the front of the engine that cannot be stopped. I have replaced belt tensioner, idler pulley, alternator, and the belt itself. I believe the squeak is constant, but I can only hear it at low speeds. What the hell could this be?
Thanks
- Curt
EDIT: Truck is a 2004 Silverado 1500 with the 5.3L, auto
Old Jul 3, 2009 | 11:09 PM
suzuki-guy's Avatar
Need more details with engine running open the hood. Be careful now! Where is it coming from? Now rev it up does it get faster? Could be Altenator making the squeak I have had that happen before really loud and annoying!!
Old Jul 4, 2009 | 6:54 AM
Koffietje's Avatar
Squeak could be any moving part with lagers in it. (Airco pump, powersteering pump, ...).
Old Jul 5, 2009 | 8:32 PM
ukrkoz's Avatar
buy yourself a tech stethoscope, it's 4 bucks at harbor freight tools.
alternator bearing comes to mind number one. every squeak i had in any car started with alternator bearing.
btw, water pump will do it just fine.
STETHOSCOPE!!!
Old Jul 5, 2009 | 9:01 PM
92chevysilvy's Avatar
Classifieds Moderator
TruckForums Liaison
Yep I've got one of them stethescopes, but I couldn't find the ticking noise on mine so while it was running I gave the belt a good dose of WD-40. Its been tick free for 2.5 months now so I must have done something right!
Old Jun 1, 2014 | 5:21 PM
gam474's Avatar
I have the same problem, changed belt, idler pulley, belt tensioner,water pump and alternator. Stops for a day or so and always comes back. Only thing left to change is the power steering and harmonic balancer. Anybody got any ideas?
Old Jun 2, 2014 | 7:11 AM
did you use a aftermarket belt or oem?
Old Jun 3, 2014 | 6:16 AM
gam474's Avatar
Thanks tech2, I finally found the problem. It was the power steering pump. The shaft pulled out about a half inch when i pulled on the pulley. The pump was causing a misalignment and a slight freying of the belt. I think this has solved the problem.
bigfredlab
Jul 11, 2011 7:04 PM
ccooper
Uplander
Sep 2, 2010 1:33 AM
jameseroot
Dec 9, 2009 4:38 PM
HollywoodBush
Jun 13, 2008 6:26 PM
jebc4
Mar 1, 2008 9:07 AM
