Platform: A-, G-, & W-body
Car honks when you lock it? 01 Chev. Lumina
Old Jul 12, 2009 | 10:57 AM
armwoodgeeksquad's Avatar
Question Car honks when you lock it? 01 Chev. Lumina
Is there a way I can do this with a 2001 Chevy Lumina? If so, instructions on how to?
uber thanks in advanced!
Old Jul 22, 2009 | 11:56 AM
Taz's Avatar
Taz
MonteCarloForum Liaison
If it's anything like the 2000 to 2005 Monte Carlos, it's done through the factory radio.
I'll try to copy and paste the info from the manual below. Hope it works for you.
__________________________________________________ _
FOB HORN
(Remote Audible Verification)
This feature allows the horn to chirp when the remote
keyless entry transmitter is used to lock or unlock
the vehicle, or to program no verification.
Programmable Modes
Mode 1:
OFF
Mode 2:
PARTIAL – One chirp for each remote LOCK
command/no chirp for remote UNLOCK command.
Mode 3:
FULL – One chirp for each remote LOCK
command/two chirps for the first remote UNLOCK
command.
Your vehicle was originally programmed to Mode 2. The
mode may have been changed since then. To determine
the current mode, or to change the mode, do the
following:
1. Scroll, using the SEEK PSCAN up or down arrows,
until FOB HORN appears on the display.
2. Press the 1 PREV or 2 NEXT button to enter the
submenu. The current selection will have an
asterisk (*) next to it. If you do not wish to change
the current mode, you can either exit the
programming mode by following the directions later
in this section or program the next feature
available on your vehicle.
3. Scroll, using the 1 PREV or 2 NEXT buttons,
through the modes to change the current mode.
4. With your preference displayed, press the TUNE
DISP button to select. A chime will be heard to
verify the new setting. The new selection will
be displayed with an asterisk (*) for one second.
If your vehicle has the optional content theft-deterrent
system, the first time a remote UNLOCK command
is received, three flashes will be seen and three horn
chirps heard to indicate an alarm condition has occurred
since last arming. See
Content Theft-Deterrent on
page 2-15
The mode you selected is now set. You can either exit
the programming mode by following the instructions
later in this section or program the next feature available
on your vehicle.
Sparky Sparks
Jan 23, 2019 10:53 AM
grnrvr
Nov 16, 2013 9:14 PM
my70chevelless
Dec 16, 2007 10:36 AM
Cavigurl85
Oct 27, 2007 9:11 AM
