Uplander 2005-2009
Platform: U-Body
Rear window washer
Old Aug 28, 2009 | 11:05 PM
rdc1534's Avatar
Default Rear window washer
On my 2007 the rear window washer does not spray just "dribbles"
does anyone know how to remove the nozzle from the door and check the tubing that carries washer fluid? and or how to clean the nozzle?
Thanks
Old Aug 29, 2009 | 7:32 AM
Papa Bear's Avatar
Is there enough fluid in the reservoir for the rear washer. I believe if the fluid is low that it is the one that is starved for fluid before the front window washers run out. I may be wrong but check to be sure there is lots of juice in the bottle.
Old Aug 29, 2009 | 12:03 PM
rdc1534's Avatar
Default fluid ok
has plenty of fluid
Old Aug 29, 2009 | 6:29 PM
Papa Bear's Avatar
Isn't it still under warranty ?? I would take it in and watch how the techs fix it ... I always ask questions of the dealership mechanics when I'm there and try to leave a little wiser than before.:0)
Old Nov 11, 2009 | 7:27 PM
dieselscout80's Avatar
So the rear washer get the fluid from the same tank as the front washers?
Old Nov 11, 2009 | 10:44 PM
Papa Bear's Avatar
Yes, I believe that is correct. The owner's manual describes the operation quite well.
mthoodequinox
May 8, 2014 8:07 PM
JoeBlow
Nov 24, 2011 10:05 AM
aaron8301
Jan 30, 2010 7:56 PM
tenman
Dec 20, 2009 7:35 AM
