need help 2002 g-2500 5.7
Old Sep 30, 2009 | 7:20 PM
johnram1500's Avatar
Default need help 2002 g-2500 5.7
fresh motor not even out the door yet. Problem is misfire monitor shows no 2 cyl missing badly. road test. shows check eng light blinking then not, then blinking again sometimes 9 times sometimes 30 times. new dis, new wires, shanged plug to no 4, nochange, changed wire to no4 no change.
changed dis cap no change. mil light does not set a code always, but misfire once in awhile. and can watch no 2 on monitor misfire regurally
need help to pin it
Old Oct 6, 2009 | 12:22 PM
stewdogg's Avatar
I have had a similar problem with an 03
anything above 55mph would result in a flashing check engine light. I could monitor the misfires on my computer and there were tow misfires on 3 and 6 I think with random jumps on all or random cylinders. I tested and tried everything and ended up giving it to the dealer and their expensive computer. They ended up performing a crankshaft variation learn procedure and that solved the problem. I even swapped out a crankshaft position sensor with another truck and no go.
Good luck!
heybuddysweetbowtie
Nov 5, 2021 5:42 PM
Cheesehead
Sep 5, 2014 9:22 PM
jacsnyder11
Feb 3, 2013 4:25 PM
toodaakerb
Mar 11, 2008 2:11 PM
Drock77
Feb 12, 2007 4:25 PM
