Astro 1985-2005
Platform: M-Body
93 Astro running rich? help!!
Old Oct 30, 2009 | 10:53 AM
majorlee's Avatar
Default 93 Astro running rich? help!!
Hi
i have had my a 93 TBi astro off the road for nearly 6 months now
been having real troubles getting it sorted, and found your forum so maybe someone can help me
atm its running far too rich, black smoke and heavy fuel usuage
so far what has been replaced:
new distributor whole unit including cap, rotor arm
electric system, plugs, leads
fuel system checked, pressure is right, injectors replaced, pressure regulator diaphram replaced and new coolant switch
oxygen sensor has been checked with multimeter and is ok
any ideas to why its still running so rich??
Old Oct 31, 2009 | 5:47 AM
Jeffro's Avatar
Do you have any codes? Have you checked the timing? Could it be the PCM? How many miles are on this vehicle?
Old Nov 1, 2009 | 9:41 AM
majorlee's Avatar
we had a code 15 last time we checked, sensor has been replaced last week
gunna do a check again on monday
she has done 80,000 miles
timing has been quadruple checked!
what is a PCM?
Old Nov 1, 2009 | 10:10 AM
Jeffro's Avatar
PCM is power train control module, in other words the computer!
I have a 93 Safari with 205,000 miles on it. It is more dependable then my 2000 Astro!
Old Nov 2, 2009 | 6:14 AM
majorlee's Avatar
going to check the water temp senders today, see if this is causing the choke to stay open
Old Nov 4, 2009 | 4:42 PM
majorlee's Avatar
all fixed
was a broken solder on the plug for the water temp sender, simple things, big trouble hey
ty for help
Old Nov 5, 2009 | 8:07 AM
ihatemybike's Avatar
Woot! Good to hear.
baycitygreasemonkey
Jun 9, 2011 12:15 PM
lawhead
Astro
Apr 23, 2011 8:56 PM
shawman
Aug 15, 2008 8:21 PM
trfollis
Mar 17, 2008 7:09 PM
Tonermaid
Feb 25, 2007 6:21 AM
