2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Problem with turn signals...
Old Oct 9, 2006 | 4:04 PM
danbailey's Avatar
Default Problem with turn signals...
I have a 2000 Impala that has an odd problem. When I first start the car, the turn signals work fine. But about 5 minutes after starting the car, the only way to make the signals work is to first turn on the hazard lights, and then cancel them while starting to signal. Any ideas would be very helpful and appreciated.
Old Oct 9, 2006 | 6:20 PM
uncle bill's Avatar
Default RE: Problem with turn signals...
Welcome to the Forum. You might Change the flasher, It's in the fuse box.
Old Oct 24, 2006 | 10:42 PM
mrborg's Avatar
I just went through this same problem with my 2000 LS. I found the solution in another forum that solved the problem. Seems the switch assembly for the hazard flasher contains a bad solder joint that is prone to going bad (GM linked certain turn signal functions in the hazard switch). Mine took seven years to fail and short in and out.
The part number on my invoice is 000010359031. Cost me $66.63 with tax from the dealer but is available in the low $40s from some Web part stores. I found another Web site (can't remember URL) to get instructions on removing the dash panel to replace the switch. Taking my time not to break the clips on the panel it took me less than 30 minutes to replace. Signals have been bullet-proof for the last month. Only difference is the turn signal indicator audible sound is much softer than the old switch.
Old Aug 26, 2007 | 2:52 PM
newcster68's Avatar
I have a 2000 Impala and im having the same issues and getting worse. When I put on the turn signal it will go at normal speed then increase and then just going crazy. Sounds like am electrical short when it starts to go fast. Then it freezes and just stays on. Now sometimes when I hit the turn signal, NOTHING, Zilche. I then noticed when I hit my flasher button just a bit the turn signals will start to work again.
So, is it the turn signal fuse or that thing in the flasher?
Old Feb 14, 2012 | 1:35 PM
Steve Sims's Avatar
im also having a problem with my '05 impala but just the right turn signal. left turn signal works just fine. hazards work just fine. it started workin out fine then started flashin fast and the front bulb wasnt flashing and the rear is goin crazy fast and thats where it is now. i thought it was the hazard switch so i replaced it and that didnt fix it. could it be the turn signal switch itself? when i turn it left only half way it does the exact same as turning it right does all the way full.
Old Feb 14, 2012 | 5:31 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Steve Sims,
I'm sorry to hear you are having this problem with your Impala. I have researched this issue; however have been unable to find any known turn signal issues for 2005 Impala vehicles within my resources.
It is possible the turn signal switch is the problem; however, I would encourage you to take the vehicle in to be inspected by a certified technician. They should be able to offer a more accurate diagnosis after a physical inspection.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Feb 23, 2012 | 2:40 PM
IMPALA239's Avatar
I am currently having the same problem with my 2000 Impala LS. I was told that it is my hazard switch itself.
Photios
Oct 24, 2020 12:08 PM
dogiboy
Nov 27, 2013 2:45 PM
Lobster 207
May 21, 2008 9:10 AM
Manor_Mullet
Apr 28, 2008 2:13 PM
boothybunch
Jan 8, 2007 11:13 PM
