Chevrolet Sonic
GM Platform: T200, T250, T300
Surging problem?
Old Nov 17, 2006 | 2:54 PM
Miracle's Avatar
Default Surging problem?
My girlfriend has a 04 4 door Aveo LT... and in the lower gears, (1 and 2) you can feel a slight "surging" around 4,200-4,500 RPM's. Kind of like you would with a SOHC VTEC on Honda, or like a VVTi on Toyota's. In higher gearing, (3rd and 4th), it is not as noticeable, but you can still tell it is happening
Is this a normal thing with Aveo's? Does it have a variable valve timing system on the motor like on other imports? Or should we start thinking about a decent tune up.
There are alot of problems with the car right now... To my trained ears, it sounds like it needs new strut bearings up front, possibly a balljoint or a tie rod, and a set of brakes.
But anyways, any idea on the surging issue at hand?
And also, I am assuming that this car came with a 3yr./36,000 mile warranty from Chevrolet... so maybe we can handle this at the dealership?
Old Aug 11, 2007 | 2:20 AM
dugsbunny's Avatar
Default RE: Surging problem?
Aveos do not have VVT engines. The powertrain warranty is 60,000 miles.
Supercharged Biscuit
Mar 3, 2013 1:21 PM
wrrn73
Nova & Chevy II
Nov 1, 2011 8:51 PM
wrrn73
Nova & Chevy II
Oct 3, 2011 9:11 PM
kan_man69
May 2, 2006 10:30 AM
aberg7039
Mar 30, 2005 12:42 PM
