Rear hatch wont stay up
Old August 31st, 2011, 1:45 PM
PacaG's Avatar
Default Rear hatch wont stay up
My Mom has a 2003 Chevy Tahoe, problem is the rear hatch wont stay up. the two cylinders ? on the top dont seem to be holding pressure. is there a way to fix these or do they need to be replaced ? Any info will help,,,,,,,,,,PacaG
Old August 31st, 2011, 2:14 PM
kevinkpk's Avatar
I'd go with an aftermarket replacement as to avoid this same issue in the future.
Old August 31st, 2011, 2:58 PM
PacaG: Welcome to the forum.
Be sure to support the hatch w/ a 2X4 or equivalent as it is VERY heavy and could seriously eat your lunch w/o the gas struts.
Old August 31st, 2011, 4:58 PM
Rickoo's Avatar
Default Search online
They are inexpensive and VERY easy to replace.
Old August 31st, 2011, 8:16 PM
PacaG's Avatar
Thanks everybody ! Looks like I found the number one site for friendly people and good info.......I will hit the parts stores tomorrow and get the struts hopefully for a quick fix thanks again.............. PacaG
Old September 1st, 2011, 11:49 AM
As stated, you can probably find the parts at your local auto parts store, if you need to find parts online, gm parts direct and rock auto are good sources as well as some of the sponsored link suppliers on the banners to the right ------>
Old September 2nd, 2011, 9:48 AM
fujixess1998's Avatar
Default Replace the pair
The same happened to my truck. I replaced both of them. It took less than 5 minutes to replace each of them. I purchased mine on eBay.........
Hood Tailgate Struts, SMALL ENGINE PARTS items in Auto Express Parts store on eBay!
Good luck!
Old September 2nd, 2011, 9:56 AM
I thought I was going to have to replace mine this past winter, turns out that they are fine it was just the cold was causing them to loose support, now that its regularly 100+ out they are fine. If they are not supporting the hatch in warm weather they are most very likely bad....
Old September 3rd, 2011, 2:27 PM
PacaG's Avatar
$45,,,,,,,10 minutes,,,,,,,,,,Good as new ! Thanks everybody ! PacaG
Old September 3rd, 2011, 2:47 PM
kevinkpk's Avatar
we are all glad you got it fixed, and thanks for posting back.
Quick Reply: Rear hatch wont stay up
