Front End Noise on 2002 Tahoe
Old Dec 4, 2005 | 9:52 PM
usrrree's Avatar
Default Front End Noise on 2002 Tahoe
On my 2002 Tahoe, I have noticed an unusual sound coming the front end. The noise is like a bumping sound accompanied by a crunching sound (likerubber contactingmetal). This only occurs when making a right hand turn. A visual inspection does not reveal anything. Whenever this noise occurs, I can feel the vibration through the steering wheel. Any ideas would be appreciated.
Old Dec 19, 2005 | 10:49 AM
HI Hoe's Avatar
Sounds like your intermediate steering shaft needs lubricating. Check with your dealer; they sell a kit for that ($20, or so). There was a TSB on this issue also that requests the dealer replace the shaft. If it's still under warranty, get them to do it.
Old Mar 26, 2006 | 8:56 PM
Endo22's Avatar
Default RE: Front End Noise on 2002 Tahoe
ORIGINAL: HI Hoe
I have an 04 Avalanche which is making the same noise. It makes a clunking type noise when turning or when hitting bumps. You can feel it in the steering wheel. I have checked the front end for any "play" and the ball joints seem fine. I think it may be the steering shaft.
My truck is no longer under warranty. Can anyone tell me how to lubricate the intermediate steering shaft. Is this the shaft that runs between the firewall and the power steering box??? I would like to fix this myself if possible. Thanks.
Old May 11, 2006 | 4:07 PM
developercanada's Avatar
Here is a link to download a tutorial on PDF to lube the steering intermediate shaft.
Cheers,
Eric.
Steering Intermediate Shaft Lube
Old May 11, 2006 | 9:40 PM
Endo22's Avatar
Thanks for the reply. I'm going to the dealership tomorrow for the shaft lube kit!
Old May 14, 2006 | 11:03 AM
viperjuice's Avatar
yeah there was a bulletin for replacement, although they realized that that wasn't fixing it for long either. So now they have an updated lube kit and it's supost to last a while.
kessiem
Sonic (Aveo)
21
Mar 28, 2021 2:42 PM
TASpinney9110
Mar 15, 2011 5:54 PM
excesss
Feb 22, 2006 9:15 PM
croscoe
Dec 18, 2005 1:09 AM
