TrailBlazer 2002-2009
knocking sound
Old Jun 5, 2007 | 12:55 PM
mgunim7631's Avatar
Default knocking sound
I hear a knocking sound that i presume comes from the front of my engine. I think it comes from the fan areaand it is itermitent. Anyone ever experienced the problem and if so, what is the fix?
Old Sep 9, 2007 | 2:49 PM
mwall1516's Avatar
Default RE: knocking sound
I am having the same problem. I hear a knocking noise in the front end only when I am idling. I notice it the most when I am at a drive-thru because my window is rolled down. I don't think it is a value because it does it at random times. I went to my local mechanic the other day. When I pulled he heard the noise and said he hadn't heard anything like that before. Then the noise stopped. He wanted $72 dollars an hour to figure out what the problem was. Any ideas?
Old Sep 30, 2007 | 9:25 PM
rmczyk's Avatar
Its the fan clutch. Common wit this vehicle both Trailblazer and envoy. the knock only occurs at idle. If you give gas it goes away. Problem Is when vehicle is not yet warmed up I believe. Mine does it too. Friend had the dealer change his fan clutch.
Old Oct 26, 2007 | 5:25 AM
clipps768's Avatar
bad idler pulley.
Old Apr 12, 2009 | 1:20 PM
RTBright's Avatar
the problem is the fan clutch, my 02 Envoy made a pinging sound from the fan area for over a year only at ilde. Then one day it finally siezed. $1,000 dollars later at the dealer it is good as new. my car only had 26000 miles when it siezed.
bigcountry25
Dec 8, 2012 3:54 AM
K-5-Titan
K5 Blazer
Mar 1, 2011 2:57 PM
Texas Cowboy
11
May 19, 2009 6:34 PM
xkikbxr
Nov 21, 2008 10:56 PM
kcrue
Feb 25, 2006 1:30 AM
