07 Z71 6in lift question
Do all 07 and newer silverado 1500 lifted 4wds look like the front end is wider than the rear end tires?...kind of like the rear end is sucked in a bit if you stand or drive behind the truck.
That's because the lift increases the track width bout an inch or so and the rear tires are left alone. Mine did it with my 6" on my 01. Just gotta order rear spacers to even it out
That sounds logical to me but one truck shop here doesn't recomend it be done, did u have any problems after you put the spacers on, what size of a spacer and brand did you use?
Thanks for info brother, I gonna getem, iam new to the forum and lifted chevys, I've pretty much had dodge diesel 4wds but with the price of diesel now a days and the cost to maintain them its crazy, so I went to the next best thing...a Chevy..if u don't mind I might private message you if I have anymore questions you seem pretty knowledgeable on this subject, thanks again.
ZachChevy
Silverado & Fullsize Pick-ups
October 16th, 2014 8:45 PM
lph008
February 22nd, 2014 7:13 PM
