Notices
Sponsored by: DashLynx
2000 silverado fuel guage problem
Old March 12th, 2008, 9:53 PM
gerkendave's Avatar
Default 2000 silverado fuel guage problem
In my 2000 1500 with the 5.3 when i fill the tank up to the top the fuel guage drops to empty, i've heard of recalls on other years but not on mine. Also when starting the truck at the pump just after a fill up it cranks alot then acts like its flooded. Just last week had an ses light come on so had it scanned and turns out to be fuel pressure sensor, if i were to replace my fuel pump would it solve all of these problems in one shot?
Old March 12th, 2008, 10:14 PM
northey87's Avatar
Default RE: 2000 silverado fuel guage problem
Welcome to the forum!!! Not sure about the recall, but your flooding problem isprobably do to a bad fuel pressure regulator. From what I understand it is not that expensive or hardto replace.
Old March 13th, 2008, 8:01 PM
Dougleo's Avatar
Very very common for fuel level sensors giving problems, causing an inaccurate guage.. But as far as not starting properly after fill up? Do you remember what the code number was? It'll start with P and then 4 numbers. Get the fuel pressure checked to see if it is, in fact the fuel pressure regulator, or the pump itself. Normal is between 55-62PSI, if I recall correctly.
Old March 16th, 2008, 1:15 AM
Coppertop71's Avatar
On a tip from another post to cure a knocking engine on the first start of the day it was suggested to use Cheveron Techron. I dumped a bottle in the tank today and was reading the lable on the side of the bottle and one of the things it says it helps to prevent is malfunctioning fuel gages. My gage drops to empy on a full tank so after I run through a tank or two I'll post some results.
97RedBull
25
September 22nd, 2010 11:24 AM
Rogers mechanical repair service
March 10th, 2010 1:14 PM
carolelannerd
May 28th, 2009 4:12 PM
ahoude23
September 7th, 2008 10:36 AM
blazinblazer
December 16th, 2006 6:44 AM
Quick Reply: 2000 silverado fuel guage problem
Top
Follow Us
