07 sliverado 5.3 po300 code and po308
Old Apr 17, 2021 | 3:49 PM
baron123's Avatar
Question 07 sliverado 5.3 po300 code and po308
Hi, my truck was showing po308 misfire cylinder 8 did a compression test was leaking...did a valve job and now getting po300 multiple misfire had a bad 02 sensor change it still getting the p0300 code. did a live data check on it and seen the long term fuel trim was above 10% on bank1 sensor1. did a fuel pressure test and found when the truck is running its at 60psi and according to the specs it needs to be at 43-45psi. its in specs when not running. Any ideal what i need to check next?
xrjoe
Mar 24, 2023 4:25 AM
Invisions1
Dec 4, 2020 6:37 PM
Blackout51
Oct 20, 2012 4:36 AM
wjm2002Chevy
18
May 8, 2012 6:51 AM
juspassinthru
Mar 8, 2011 5:16 PM
