5.7 Lifter Replacement, Should I replace the cam also?
I have a 99 5.7 in a Suburban that has 3 trashed lifters. I was going to replace all of the lifters, should I replace the cam as well? I was just going to do the lifters then I pulled one & looked at the roller, thought I'd ask before I continued. I haven't replaced a cam before. If I do replace the cam, what bearings, thrust washer, etc... should I replace with it or just swap out the cam? Thanks
I would change the camshaft since you already have it partially tore down. The lifters show some uneven wear and debris could have marred the cam.
A new thrust washer is not that much and best to be replaced. The cam bearings are a different story, I would do as good of a visual inspection as possible and if you have the tools also check to see the diameter of at least the front bearing to see how worn it is.
Replacing the cam bearings while the engine is in the vehicle is damn near impossible.
Make sure you also inspect the pushrods especially those on the lifters that are damaged.
John Mason
Silverado & Fullsize Pick-ups
April 15th, 2015 8:18 AM
noonans
December 12th, 2014 4:29 PM
tjstockton
August 28th, 2009 8:01 PM
