Notices
Sponsored by: DashLynx
Old July 24th, 2015, 1:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Brakes
Print Wikipost
Brake Booster or Master cylinder
Old May 5th, 2009, 2:34 PM
randys94's Avatar
Default Brake Booster or Master cylinder
Hey this is my 1st post, i have a real quickk problem i need help with, this guy has a 1999 1500 chevy v6 ( im guessing silverado) and his brakes went out on him. i took a look at it and there was no fluid left in the reservoir, it had all leaked out, he said he would hafta pump it a few times before it would work, and before he got home he said it had gotten to the point of not working. well i had a thought it was the brake booster? i put my hand on it and there was fluid all over it, so i removed the brake booster and the master clyinder but after looking up some info on google im not sure which one it was now.... do yall have any idea?
also i noticed after removing the brake booster that 1 of the 4 bolts on the booster has a tiny leak around it?
Old May 5th, 2009, 4:23 PM
suzuki-guy's Avatar
it sounds like master cylinder but if you said there was leaks you should fix those to
Old May 5th, 2009, 4:58 PM
randys94's Avatar
so its the MC thats leaking?
Old May 5th, 2009, 5:10 PM
suzuki-guy's Avatar
Thats what i think i would also check your lines for cracks or rust
Old May 5th, 2009, 5:15 PM
therewolf's Avatar
The boosters tend to last longer than the M/Cs.
Replace the M/C and see if that doesn't fix her.
Old May 5th, 2009, 5:39 PM
Banned
shawnvw's Avatar
the booster wouldn't leak fluid.....it is strickly vacuum operated.
The seal on the master right where the rod from the brake pedal is leaking and it goes into the booster.
Put a master cylinder on it and you should be good to go.
Don't forget to bench bleed it before you install it
Old May 6th, 2009, 8:53 AM
randys94's Avatar
ty im gonna try the mc today, sucks cause i took the brake booster off and that was a pain in the **** to do.. just time consuming trying to get thoses 4 nuts off. gonna hafta go get some better tools
Old May 6th, 2009, 1:10 PM
oih82w8's Avatar
This may sound sill, but it happens... was the filler cap to the Master Cylinder fully seated?
Shoot you some PB Blaster on the nuts, let it sit for spell, and then take a whack at bustin' 'em.
success,
Old May 14th, 2009, 9:39 PM
95burban's Avatar
your master cylinder whent out the Booster has no fluid in it its a vacuum operated
Booster..
My Brake booster when out and its a pain in the *** to change..
jason78
April 13th, 2014 2:40 PM
jasonthatsme
Express & G-Series Vans
15
August 6th, 2013 7:24 AM
qzack1
August 28th, 2011 12:50 PM
aussie chevyguy
December 8th, 2010 7:00 AM
Donald91
August 9th, 2010 9:53 AM
Quick Reply: Brake Booster or Master cylinder
