Notices
Sponsored by: DashLynx
Old July 27th, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
A/C fan motor will not stop!
Old April 13th, 2011, 1:21 PM
marsala4's Avatar
Default A/C fan motor will not stop!
I have an 06' Silverado, the a/c, heater fan motor absolutely will not shut off unless I pull the fuse. It will run even without the key in the ignition. The only way to keep from running the battery dead is the pull the fuse under the hood. (40 amp). I tried swapping the fuse but it did not stop the fan motor. As soon as I plug the fuse in the fan motor starts running. Please help.
Old April 13th, 2011, 5:33 PM
EinST's Avatar
Welcome to the forum. If I'm getting this right, the blower motor runs at full speed with the 40A blower fuse in, even with key off. The switch setting on the HVAC control module probably has no effect either. About the only way it can happen is if the blower motor relay is stuck on the 40A blower fused source. This relay is part of the blower motor resistor assembly which isn't too bad to replace on the Silverado.
Old April 13th, 2011, 9:10 PM
I concur, the relay welding itself on is common...replacing the relay will most likely resolve the issue...
Old April 14th, 2011, 5:00 AM
marsala4's Avatar
Thanks to both of you for responding so quickly. EinST you have it correct. Today I will visit my friend at the local salvage yard to find replacement relay. Hopefully this will not cost me much. I will post the result of the change as I am sure I am not the first to have this problem nor the last to seek help to fix it.
pdrayton
June 16th, 2021 8:00 PM
pdrayton
May 29th, 2013 7:55 PM
SweetEmotion
April 27th, 2012 8:35 PM
zulu
April 18th, 2007 10:32 AM
Quick Reply: A/C fan motor will not stop!
