engine knock/piston slap??HELP
Hello all Im new to CF. I am lucky enough to have one of the 01 2500hdsilverado's with the famous " piston slap" noise. I have tried the easy fixes that I have heard from friends.....The questions I have areof course is there any fix for this? If not.What about replacing the engine? What would be the cost of an engine replacment? As im sure with anyone else that has this problem it is driving me nuts..
Thanks
John V.
Washington St
Thanks
John V.
Washington St
RE: engine knock/piston slap??HELP
Hi Scoyoc5
What engine do you have, and how many miles on it? What kind of driving do you do? Any towing ofheavy loads? Have you found out yet what is causing the slap, and have you fixed the problem? I think changing the engine would be uncalled for, and a very expensive fix unless you haveseveral thousand dollars to spend .I have an 02 2500HD with the 8.1 engine and tow a 5th wheel with max allowed weight. I have about 88K miles on it and absolutely no problems with anything.
you could swap engines but the new one would prolly do the same over time....this is inherent of big block GM engines from 454, to the 8.1 and even the old 5.7....get used to it...sorry and my cost on a 350 crate engine for my jeep was around $2500 NOT COMPLETE.....a complete bolt in one was about 4000 if I remember, a 502 goes for around 9G this is canadian.....dont know where u are...but figure somewhre in there....plus re and re
Hey guys,
To answer some of your questions. I have the 6.0L with only 70,000 miles. I started hearing the noise somewhere around 55,000 if I remember right. I hate this noise! I do tow a 27' travel trailer.I love my silveradoand have enough money into it that I want to fix it. 6" rcd lift 35" toyo's stone crusher weld wheels. Im just hoping to find that one fix that will solve this issue. Thanks for you respones
John
P.S. I live in Washington St.
John
Stech
Silverado & Fullsize Pick-ups
March 16th, 2010 12:22 PM
