error code
not a valid code for a 2000 pick up.
Are you using a scan tool that is not updated and entering a different model year?
Is there a problem with the truck or just the mystery dtc?
prefix B are body codes set by the bcm and related modules ie. sir, ipc, hvac modules
c codes are chassis codes and abs, traction control, powersteering modules would fall in this area
U codes or undefined codes are network communication codes
P are powertrain codes
The body code that was posted is not used for a 2000 pick-up.
Mother_Trucker
Silverado & Fullsize Pick-ups
September 10th, 2006 12:01 AM
