Notices
Sponsored by: DashLynx
help cant figure out help
Old February 15th, 2014, 8:44 AM
luni1974's Avatar
Default help cant figure out help
anyone have any ideas what my problem could be.....
i have a 94 k2500 4x4 5.7.......it shuts off on idle, in park and in gear as well as coming to a stop and if you take foot off gas and push again....also when shuts off wont start for atleast 30 min.....
i have changed egr,egr solinoid,ecm,map,coil,fuel pump,fuel pump relay,fuel pressure regulator,rebuilt throttle body....
please help...thanx
Old February 15th, 2014, 1:19 PM
Allan In NE's Avatar
Check the ignition switch.
Allan
Old February 19th, 2014, 10:50 AM
'03 Heavy Chevy's Avatar
please help...thanx
Ditto to Allan. Sounds like the ignition switch is worn out.
By chance do you keep a lot of keys on the same key ring with your truck key? If so, take off as many as you can. The extra weight can wear down the internal parts of the ignition switch. (yes I know that keys don't weigh a lot, but for the ignition switch, anything more than the ignition key is extra and unnecessary weight). I use a quick disconnect key ring to keep the extra keys off the key ring with the ignition.
Hope this helps!
Old February 20th, 2014, 8:54 PM
luni1974's Avatar
thanx for info will look into this weekend
Old February 23rd, 2014, 5:51 PM
luni1974's Avatar
i changed ignition switch did not change now turns over sometimes starts does not run long..when you turn key sometimes you hear pump most times dont and smells like flooding with fuel..what do i do any ideas about to get rid of truck
Old February 23rd, 2014, 7:05 PM
did you index the switch correctly?
Old February 26th, 2014, 4:40 PM
luni1974's Avatar
yes i did.....it ran with no problem for about 15 min i turned on and of repeatedly about 10 times started every time let idle for 15-20 min turned off for about 1hr and would not start...if i let it go cold it will start drive about 2 blocks will turn off sometimes it will restart if i turn it off come for couple min wont start for atleast 20 45 min and then starts ....i am lost dont know what to do...also turns off when braking to turn or stop have to flutter gas...
Old February 26th, 2014, 4:47 PM
Pugly's Avatar
I would think more along the line of the pickup assembly inside the distributor.
I learned one thing many many years ago - if you're going to guess start with the cheapest part first.
Old February 26th, 2014, 7:51 PM
luni1974's Avatar
thanx for info i will try that next
bgtmtdew5
September 22nd, 2013 4:00 PM
Bedo
November 16th, 2012 5:02 PM
tboz
Express & G-Series Vans
May 21st, 2010 9:08 PM
19899c1
January 22nd, 2008 2:36 PM
AstrosRule
July 9th, 2007 3:36 PM
Quick Reply: help cant figure out help
