Notices
Sponsored by: DashLynx
High mileage club!!!!!!!!!
Old April 19th, 2015, 8:26 AM
  #181
Just finished cleaning it up. Its not at 900 000 but its been around the block. 2000 with 355 000km.
Old April 19th, 2015, 12:02 PM
  #182
Roadhogg2004's Avatar
Originally Posted by Georgiey22
Congratulations 97blacksilverado!! We would love to see a photo of your odometer?
What maintanence have you completed over the years?
Have you ever replaced the timing chain and gears ?
Old April 19th, 2015, 12:12 PM
  #183
You have not changed the timing chain and gears yet ?
Old April 19th, 2015, 8:44 PM
  #184
GEOMAC's Avatar
1 more oil change before hitting 500,000 on my 2000 1500 LT. Original 5.3. Tranny rebuilt at 355,000.
Old June 17th, 2015, 8:09 PM
  #185
KChevy75's Avatar
2007 Suburban LTZ 5.3L, 4L60e. Just hit 202,650 Miles.
I broke the forward sprag in the trans at 202,495 miles. I believe that was due to a bad pressure switch manifold which was causing harsh shifting issue. I pulled it all apart and rebuilt it. I was surprised to find that the friction materials were all within spec still. Only the 2-4 band would have needed replacement if it wasn't for the broken sprag and bad pressure manifold switch.
The engine runs like new.
I only run Mobil 1 and change it about every 6-8K miles.
Old June 24th, 2015, 4:02 PM
  #186
Philntx's Avatar
2010 Z71 LTZ extended cab. 170,000 miles. No problems.
Over the last 128 fillups, it's averaged 18.1 mpg with the 3.42 gears
9/3/15 update. Now at 177,000
Old July 16th, 2015, 1:30 PM
  #187
Former Sponsor
TRS Andrew's Avatar
Crazy how much some of you guys drive. I guess if the duty calls...
Old August 27th, 2015, 8:29 PM
  #188
New User
Awaiting E-mail Confirmation
Rusty92's Avatar
Default 300+
I got a 1992 c1500 daily driver with 326+. Still has plenty of power and runs like a top. Never had a rebuild and all original.
Old December 1st, 2015, 4:41 PM
  #189
Serenna Wright's Avatar
Default 1995 Chevy Astro Van
I am proud to claim bragging rights for over 329,000 miles on the original engine and still going strong! She's a Missouri van with stamina!
Old January 4th, 2016, 4:17 PM
  #190
Georgiey22's Avatar
Own a 1999 Silverado single cab short bed with the 5.3L. In the year that I have owned it I've driven 10K miles, truck now has 86K miles. I know, low total miles on the truck but it is so cool to have a 17 year old truck that runs so well. For precautionary measures I completed the following work at 80K miles. Switched the truck from conventional to 0W30 Mobil 1 oil (all ticking during warmup is gone)! Replaced the water pump, replaced the replaced the engine belt, replaced the AC belt, replaced the transmission filter and pan gasket and fresh Valvoline synthetic ATF, replaced the fuel filter, replaced the rear axles/axle gaskets/pumpkin gasket and fresh Mobil 1 gear fluid, replaced the rear and front rotors along with brake pads, replaced the e-brake pads, replaced the Sparks Plugs and Plug wires, cleaned out the throttle body, added a new air raid engine filter and installed a remote engine start so I can warm the truck up before I get into it in the AM before work. Next I will pull the valve covers off and install new Fel-Pro gaskets, however this won't occur until I start seeing oil leaks.
Quick Reply: High mileage club!!!!!!!!!
