Notices
Sponsored by: DashLynx
im at a loss
Old March 2nd, 2013, 8:28 PM
eastbound's Avatar
Default im at a loss
i have a 95 k 1500 z71 i have replaced o2 sensor three times, map, egr valve,purge valve, temp sensor on the side of the block and injectors full tune up fuel filter and ecm and still have a code 13 and its running very rich all the wire seem to be in tact inside th wire loom ....code 13 is a open circut or low activity with o2 sensor ....please any suggestions would be absolutely awsome thanks in asvanced!
Old March 2nd, 2013, 8:41 PM
are the exhaust manifolds or y-pipe cracked , not sealing or leaking?
Old March 2nd, 2013, 8:59 PM
eastbound's Avatar
no exhaust leaks and no vacuum leaks
Old March 2nd, 2013, 9:14 PM
is this throttle body or multi point fuel injection? If multi point injection, what is the fuel pressure at?
Old March 2nd, 2013, 9:23 PM
eastbound's Avatar
throttle body inj.
Old March 2nd, 2013, 10:19 PM
cleveland63b's Avatar
stock exhaust manifold?
Old March 3rd, 2013, 9:40 AM
eastbound's Avatar
Yes everything is stock i found another coolant sensor next to the thermostat would that sensor cause a code 13
Old March 3rd, 2013, 2:05 PM
kevinkpk's Avatar
What I read code 13 is left bank O2 sensor open, or no input. I don't know what the resistance is supposed to be, but open circuit is just that. Replace the part, or at least inspect the wire connector.
Old March 3rd, 2013, 2:51 PM
eastbound's Avatar
I have cked the resistance and replaced yhe o2 3 times and still have that code
Old March 3rd, 2013, 2:56 PM
kevinkpk's Avatar
Has it been cleared?
Quick Reply: im at a loss
