Notices
Sponsored by: DashLynx
Need advice on overheating 454
Old August 7th, 2014, 2:46 PM
Cricketo99's Avatar
Default Need advice on overheating 454
I know this is technically the wrong forum for this but it does have a 454 engine. The truck is a '99 c5500 which i believe is called a topkick. I am having problems with it almost overheating. If I start it up and let it idle it will reach operating temperature and stay put. If I am putting around town when I pull up to a stoplight it will climb maybe 10 degrees or so (according to the dash gauge) and then level off. If I take it on the freeway it will maintain the correct temperature but once I hit the exit ramp and slow down the gauge will creep upwards. If I hit a stoplight right after the ramp it will sometimes climb to 220 or 230, enough to make the check gauges light come on. If I rev the engine it will cool it down fairly quickly. I have changed the thermostat, mainly because they are cheap and easy to replace. I have verified that the gauge is pretty much correct via my scantool. I am leaning towards fan clutch but thought I would get some insight before I bite the bullet as it is about a $5-600 part. The fan will roar like they all do at first start and then quiet down. After it has reached operating temp I can stick a piece of cardboard in the fan and stop it. It takes a decent amount of force but I can stop it. I was thinking of removing the water pump just to have a look at it to see if it was corroded. Other than that about the only other thing I could think would be the radiator but since the truck only has 29,000 miles on it I would think it would be okay. Oh and no steam out the tailpipe and no milky oil or oily coolant. Any help is greatly appreciated.
John Gosselin
January 11th, 2015 12:27 PM
core shift lsx 454
November 18th, 2012 3:35 PM
heavychevy511
October 31st, 2012 8:43 PM
woodstockaz
August 15th, 2010 4:08 PM
xfiscal
July 28th, 2009 9:33 AM
Quick Reply: Need advice on overheating 454
